Tranny fluid
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by loudandproud, May 23, 2001.
  1. loudandproud
    loudandproud 1/2 ton status
    Jun 27, 2000
    451
    Ham Lake, Minnesota
    My 700R4 tranny is slipping between 1st and 2nd gear and between 2nd and 3rd gear, could it possilby just be the tranny fluid that needs to be changed??? Man I hope thats all it is. [​IMG]
    <font color=red>_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _</font color=red>
    <font color=blue>'90 Jimmy</font color=blue>
    <A target="_blank" HREF=http://loudandproud.coloradok5.com>http://loudandproud.coloradok5.com</A>
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Well, I would try that first before I jumped to any conclusions.
    My president is Steve Fox.
    90-350TBI-TCI700-241-33"-10 bolts w/4.10's,
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  3. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Change fluid and filter. How many miles are on tranny?
  4. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Mine is a 90 and Im gonna guess 125,000 or more.
  5. loudandproud
    Jun 27, 2000
    451
    Ham Lake, Minnesota
    Yeah I've got about 125,000 miles too, I don't remeber exactly and its too late to go out and look.
    I will be changing the fluid and filter soon then, until then the truck just sits [​IMG]
  6. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    I've actually got 152,00o on mine. And it has just now started hinting of problems.
  7. J.R.
    J.R. Guest
    try this, after you have been driving a while and have your truck good and warmed up. check your fluid and smell it, if it smells burnt and is a very dark or blood color then you have an internal problem in your trans. changing fluid will help but sooner or later it needs to be replaced. good luck
    BIGBLOCK MAN
  8. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I put a quart of B&M trick shift fluid in my 700r4 when I change the fluid. It makes it shift smoother and quicker. On a 700r4 you should change the fluid once a year. they dont like dirty burnt fluid. it should always be nice and pink if not change it soon
  9. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    How many miles has it been since you serviced the tranny? Reason I ask, is if it's way over due the deturgent in the new oil will eat up your soft parts in there. On a tranny that hasn't been serviced in a long time it's better just to keep the old fluid in there and just start saving for a rebuild. It's happened to me twice where I'll buy a truck and do all the service that it needs just so I know when it was done and then about a month or two later, it's getting the tranny rebuilt.
    If it's been serviced like it's supposed to, then change the tranny fluid, put an additive in there that will make it a little slicker, and see how it goes.
    But if the fluid in there is brown and discolored, you might be on your way to tranny failure. The slick additive will help it to go longer.
    Imagine a cowgirl twirling a rope.
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
