Tranny ? GURU's Needed.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by i_4x4, Mar 27, 2001.
  1. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    Tranny ? GURU\'s Needed.
    I have a 700r4 that i need to remove the pump. I want to install a short output shaft. So I can do the Doubler.
    Later ED
    Thanks in advance.
    LET'S ROCK
    Don't follow me you will get STUCK!!
  2. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Re: Tranny ? GURU\'s Needed.
    Gotta take it all the way down, I'm sure you knew that. If you haven't been in one I'd get a body who has. Or take it to some one. Sorry I can't help you much with this one.
    Twiztid
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You have to remove way more than the pump. You have to remove all the guts from the trans, remove the old output shaft and then install the new output shaft. Next you get to put all that stuff back inside the tranny. [​IMG] A buddy of mine just did this to a 700R4 that he's installing in a Jeep. He had to change the output shaft to one that would mate up with his Dana 300 transfer case. He swears it wasn't that hard to do....
  4. blazbrnc
    blazbrnc 1/2 ton status
    Mar 16, 2001
    181
    southern MI
    You are probably going to need a special tool to pull the pump. It is a steel sleeve that goes around the input shaft and clamps on the pump. It has a threaded rod on the end that is screwed down onto the input shaft which in turn pulls the pump. After that you will have to remove a few drums and bands. Keep an eye out for falling one way roller pieces. The hardest part about tranny work is how to hold onto the tranny when you are working on it. It is best to have the bellhousing pointing towards the sky. I have tried other ways and it won't go together. You are also going to need some small pry bars to remove the large snap rings that hold down the clutch packs. Just lay everything out in the order that you take it out and it shouldn't be a problem. Good luck.
  5. i_4x4
    Feb 20, 2000
    359
    I guess i'll see if any tranny shops will give up ant secret's. Thanks for the replies. I was hoping to do it myself and save some cash.
    Later Ed
    LET'S ROCK
  6. willcofab
    willcofab Registered Member
    Mar 29, 2001
    27
    RockMountain, Wy
    Hey dude! I actually know someone in here! Did you get my reply to your ad on CO? anyway, L8R! [​IMG] I'm Tanks4Toys in there!
    <font color=green>"if you build it, they will buy it"</font color=green>
    Contacthutch58wyo@aol.com
  7. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    If thats all your going to have to do to it hten no its not that bad. Its not that bad if you have to rebuild it. Its just that you have to KNOW what you are doing.
    But to swap out the shaft all you have to do is take everything out and keep it in chronilogical order. Put it all back in the same what it came out. I would however, recommend, since you have it apart, to get a new ring and seal overhaul kit. They are like less than 100 bones. And clean it up real good . The worst part will be compressing those springs around the sprag assembly, I think its called. It been a while, sorry for the lack of term recognition. Go for it.
    Will work for beer, parts and tools.
    90 Jimmy 350TBI-700R4-241-33" BFGs-10 bolts w/4.10's
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  8. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    One more thing...... Get on Amazon.com and get a book in the Automotive section on GM transmissions. It is very detailed. It will help you if you get lost in the re-install. And recommend new things in the process.
  9. i_4x4
    Feb 20, 2000
    359
    Hey willco, ya i replied still have that 12 pack w/ your name on it.
    Later Ed
    LET'S ROCK
