Tranny Guru's-Tranny starting to "shudder"? How come?
Discussion in 'The Garage' started by Flexy K20, Dec 3, 2002.
  1. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    Tranny Guru\'s-Tranny starting to \"shudder\"? How come?
    The tranny strated doing this the other day, it's a 700R4, 208 combo. It really only does it under accleration. Why? Any help would be great. -Thanks
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Re: Tranny Guru\'s-Tranny starting to \"shudder\"? How come?
    Sounds like your lock up converter could be failing.
  3. exodus
    exodus Registered Member
    Oct 4, 2002
    16
    alabama
    Or your pump might be bad and not giving it enough line pressure to engage the gear fully
  4. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I'd go for simple, and check the tranny mount first since it's cheaper...
  5. Flexy K20
    Oct 22, 2002
    398
    Bay Area, CA
    The shudder or shimmy is very slight, and you can barley feel it. I have just recently changed the fluid and
    filter so let me know what I should do. Thanks
    -Flexy
  6. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    I hate to say this but the TH700 in my S-10 did started doing that a few months before it died.
  7. wakedog
    wakedog 1/2 ton status
    Mar 7, 2001
    233
    Minnesota
    mines been doing the same thing for the past few months and its getting really annoying so im thinking that the tranny is about to go. Perfect exucse to upgrade to Caddy 500 stroker, th400 and a 205.
  8. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Your converter is officially gone...switch it out now before it really screws everything up and you have to rebuild it. Both my S-10's and my Burb did that before the trannies went.
  9. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    i was at the badlands and my would rev up then "pop" into gear. well i drove back a mile to try to put it in 2hi to drive home and it wouldnt move. my TC sent metal through out the whole thing. so we towed it back. so now im puttin in a new tranny and TC.
    NITRO
