tranny help
Discussion in 'The Garage' started by deadtoyou, May 28, 2005.
  1. deadtoyou
    deadtoyou Registered Member
    May 22, 2004
    36
    spokane
    my truck was stuck in the mud awhile back i got it out and found out where it was leaking fluid from, right where the vac mod plugs in, i pulled it off and this little shaft came out of the hole, whats my problem? thanks
  2. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    modulator...
    That shiny "pin" is the modulator valve--it goes into the tranny case first,then the vacuum modulator goes in after that(there is a spring in the :hole: it goes into)--a "fork" looking thing with one bolt holds in the both of them onto the tranny..you might have lost the fork or the bolt and they fell out..that'll spoil a day fast.... :frown1:
  3. deadtoyou
    May 22, 2004
    36
    spokane
    so does that pin just slide back in there or am i ****ed?
  4. deadtoyou
    May 22, 2004
    36
    spokane
    anyone?
  5. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    yhes, the pin just slides back and forth in there
