tranny help?
Discussion in 'The Garage' started by bigblue82, Aug 22, 2006.
  1. bigblue82
    bigblue82 Registered Member
    Jul 1, 2006
    30
    sc
    I replaced the gaskets on top of the motor and now the transmission wont shift out of first.I think it may be a vacuum problem.Is there a place i can get a diagram for the vacuum system?Is there something else i may have left off? :confused:
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    did you plug the line that runs to the modulator back into manifold vaccum? It sounds like you did not if it is not shifting out of first
  3. bigblue82
    Jul 1, 2006
    30
    sc
    yea i made sure it was hooked up.Could it be a timing issue?
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    did you hook it up to a direct port or a tempature switched port? as long as you are getting vacuum to your modulator you should have no problem with shifting
  5. bigblue82
    Jul 1, 2006
    30
    sc
    the one on the intake manifold between carb and dist.
  6. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Is your transmission a TH350 or a 700R4? If it's a 700R4, was the TV cable correctly adjusted after you reattached it?
  7. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Check at the trans to make sure your vacuum line didn't pull off of the modulator valve.
