Tranny help
Discussion in 'The Garage' started by Bustah, Mar 11, 2007.
  1. Bustah
    Bustah Registered Member
    Jul 25, 2005
    9
    Boothbay Harbor Maine
    I know a manual shift valvebody makes it so you have to shift an automatic tranny. Can you shift at full throttle? Also I see auto/manual shift valvebody's whats the differance from a man shift valvebody
  2. chris walker
    chris walker Registered Member
    Sep 5, 2005
    42
    Arizona
    you can shift full throatle but its hard on u-joints and the auto/manual bodies still retain auto fetures such as it shifts itself if you put it in drive but it also lets you shift when you want to and will keep the trans in the gears you choose
  3. AFUFO
    AFUFO 1/2 ton status
    Apr 26, 2006
    329
    Chesapeake,Virginia
    Auto/manual automatic transmission..
    Ok you have 4 gears
    Your selector says
    D 3 2 1
    D is 1-2-3-4, and when you select 3, its in 3, when you select 2, its in 2.. same as the manual valve body except for the automatic shifting in D, and the 3-1 pattern may be reversed so it actually functions as D-1-2-3, but im not sure.. I think i may be confusing the selector pattern reversal with a fully manual valve body.
  4. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    no thats right...when they do a reverse pattern it is D-1-2-3-4
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    A full manual kit also does not care what position the throttle is in when you shift it will have full line pressure to all shifts regardless of engine RPMs so it is hard on drivetrain components regardless of how you drive. I also have not seen a kit for a 700 that will retain any automatic features.
    As was stated earlier to have a PRN1234 shift pattern you need a reverse manual valve body.
    Ira
