tranny help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by havok, Jan 17, 2003.
  1. havok
    havok Newbie
    Jan 17, 2003
    I just got a 84 K5 4x4 and looking to do lots to it. Well I was driving it the other day and one of the tranny lines came off and started to leak everwhere. I drove it to a friends and fixed the line. Now I don't have the final gear now, whenever it shifts, it just acts like its in nutural. Any Ideas?
    Phil
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    First thing to check is the fluid level. Make sure it's at the proper level. Otherwise, the tranny may not have enough fluid to make the proper pressure to run o.d.
  3. havok
    havok Newbie
    Jan 17, 2003
    It says I have 2 much tranny fluid in it now, but I know more came out than I put back in. Is there a way to get teh air out or something like that that may be in the tranny?
    Phil
    /forums/images/graemlins/1zhelp.gif
  4. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Check the tranny fluid level when it's hot and in park.
    Get the fluid level to the right level on the dipstick.
    Make sure the vaccuum line is hooked up from the manifold on the engine to the vaccuum modulator on the transmission.
    Double check the shifter linkage that its not binding up or in between gears or something.
    Otherwise it sounds like it may be something more serious.
  5. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    About how much fluid might you have lost? Same thing happened to me on a long trip when my tranny had a really bad front seal leak. I lost so much that 3rd and 4th blew out.
  6. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    Check the fluid level with the engine running, the transmission at typical operating temperature and in park. If you check it with the engine not running it will read higher than when the engines running.
