Tranny in a 94 Dodge Ram...Expensive/easy/difficult?
Discussion in 'The Garage' started by newyorkin, Dec 28, 2005.
  1. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    So uh...sticking this here in the garage...
    I'm thinking about running to queens a little later to look at a 94 Dodge Ram with a V6.
    He says it's "sluggish in reverse", needs a tune-up and TLC. 141k.
    It's $800... This would be a steal if I could find a tranny for under $1000. Any more than that, I might as well spend more on a better truck...
    Body is in exellent condition, not rust, no real bad paint.
    So anyone have any ideas?
  2. gotmud77
    gotmud77 1/2 ton status
    Aug 4, 2003
    689
    bellefonte
    In most cases you will have between 1200-2300 in a dodge tranny. It sounds like a good deal on the truck but after you figure in the cost of the trans its not looking so good. As for the work to put it in its not to bad.. Just dont take the crossmember out. Its tappered and you will have a hard time getting it back in there. I found out the hard way.
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
  4. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    that will have a 42RH in it, pretty much a 904 with overdrive
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    dodge trannys leave something to be desired. maybe find a way to mount up a 700r4 hehe
  6. francis
    francis Registered Member
    Oct 11, 2005
    79
    kemp, texas
    not to bad
    I pull these things and install these things all day they are not that bad. on avg. my shop does a remove rebuild install with a rebuilt torque converter for 1000 to 1500 dollars. If you pull it you can bring the cost way down. my shop does a "bench build" for 200 plus parts
  7. dave_90_blazer
    Jan 1, 2004
    688
    agreed, these are pretty easy to pull out of a 94 ram as well, 2wd is much easier then 4x4
    if you do this, be careful when removing ot that you don't hurt the crank sensor(on engine at the bellhousing, behind the pass side head) and don't pinch the wires upon reinstallation
  8. francis
    Oct 11, 2005
    79
    kemp, texas
    yes that is so true it is a pain in the bung hole to re place the egr is right in th way thanks for puting in what i forgot
  9. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Cool, thanks for the info guys, that makes me a little more confident, maybe I'll run over with cash today...
