Tranny info
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RAY, Nov 25, 2000.
  1. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    I was driving on the interstate going to Thanksgiving dinner. I had the cruise control on going up a hill, it shifted into drive, but as it attempted to shift down again, nothing happened except that the RPMs went up and there was a grinding noise. I immediately hit the brake to cut off the cruise control. I thinking the it has something to do with the torque convertor but I'm not sure. Any info would be greatly appreciated. Thanks
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Almost sounds like the t-case came out of gear. What happened after you hit the brakes- what did you do to recover?
    <font color=blue>Maverick</font color=blue> <font color=red>CH 4 or 35</font color=red>
  3. RAY
    Jul 4, 2000
    281
    Austin, Texas
    When I hit the brakes to shut off the cruise control, it slowed down a drove normal after that. In fact, I remember moving of to pass someone and it did the same thing, it almost sounds like the transmission is slipping because the engine revs up but nothing happens.
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Ok, I get it now. could be alot of different things, but most likely the tranny needs rebuilt if it's the stock one (700-R4). One of the hydraulic circuits isn't releasing all the way. If it's a newer tranny (not a bad idea on an older one either), check your linkages, and other external stuff. If it is slipping internally, chances are you have many worn out parts inside. It will only get worse....
  5. RAY
    Jul 4, 2000
    281
    Austin, Texas
    FWP, the tranny was rebuilt in 97, I wonder if it needs to be rebuild again. Any suggestions?
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I would check all the other simple stuff first. The TV cable is critical to proper shifting. The shift linkage also controls a valve, and if it's not right, will cause problems as well. There are a couple of other 700R4 posts on the board that have some really good info, check em out. I am not that familiar with that tranny. I like TH350s or 400s. good luck.
  7. Jackson 88K5
    Jackson 88K5 1/2 ton status
    Oct 27, 2000
    104
    Topsham, Maine, USA
    My 700R4 was slipping when taking off form a stopped position. After several days it finally went. I found out later that the torque converter was shot. It ended up sending metal throughout the tranny. I had it rebuilt with better stuff.
    If it breaks...upgrade it...[​IMG]
    http://www.tjcommons.com/88K5/
