Tranny Issues
Discussion in 'The Garage' started by Justin Fleming, Dec 16, 2005.
  1. Justin Fleming
    Justin Fleming 1/2 ton status Premium Member
    Aug 24, 2005
    765
    4
    Oxford MI
    Hello
    I have an 86 k5 blazer. Last night evrything worked well....today when I took it out the trans did not seem to want to shift out of 1st gear. I really had to wind it up very high before it would shift. Other wise when I wind it up really high and then let off it still does not shift, but it seems to go into like a stall and when I gen back into the gas it revs then engauges into 1st.....any ideas?
    It does shift out of 1st if I tack it out and then it goes into second....
    seems like something is sicking or something
  2. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    which tranny?
  3. Justin Fleming
    Aug 24, 2005
    765
    4
    Oxford MI
    I beleive it is the 700r4 it has over drive
  4. MOBK5
    MOBK5 1/2 ton status
    Apr 5, 2005
    180
    MCAS Cherry Point, NC
    Check the fluids?
  5. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    comon problem i found with my 700s was the regulator valve in the pump went bad and stuck full pressure. same exact symtems.
  6. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    mine is doing the exact same thing right now, it has been acting funny for the last couple years, so i am going to swap it with a different used one, then take my time and rebuild it
  7. sweetk30
    Nov 1, 2004
    25,526
    526
    i swaped mine out already to a 4l80-e tranny. no more junky 700s in my trucks.
  8. Justin Fleming
    Aug 24, 2005
    765
    4
    Oxford MI
    How Bad is it to replace this regulator valve??
  9. Justin Fleming
    Aug 24, 2005
    765
    4
    Oxford MI
    Does anyone have any diagrams or exploded views of this tranny
  10. Justin Fleming
    Aug 24, 2005
    765
    4
    Oxford MI
    anyone anyone
    :doah:
  11. Justin Fleming
    Aug 24, 2005
    765
    4
    Oxford MI
    Anyone???:doah:
  12. George_Pimpdaddy
    George_Pimpdaddy 1/2 ton status
    Oct 17, 2002
    1,306
    Edmonton Alberta Canada
    ive got the same **** happening to me too my 89 blazer has an 700r4 and lately it wount **** out of 1st till you hammer it and my tv cable is adjusted properly. also after a short while of driving i lose reverse. and have to shut the truck off and wait a couple of seconds to start it back up and use reverse. is there an easy fix to this or waht steps should i take
  13. dave_90_blazer
    Jan 1, 2004
    688
    mine is the same way, I'm swaping the trans, then i'll go through the one i pull out
