tranny leak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by nerraw117, Mar 28, 2005.
  1. nerraw117
    nerraw117 1/2 ton status
    Jan 5, 2005
    788
    charlotte, NC
    i am pretty sure i have a leake where the kickdown cable enters the transmission. my questions is (i searched) does anyone have a pic of a th-350 where the kickdown cable enters the tranny? i looked under there but didnt know what it looked like thx :grin:
  2. sweetk30
    Nov 1, 2004
    25,528
    527
    horseheads , ny 14845
    just fallow the cable down, its on the right side by the fill tube. 1 bolt holds it in. and its a oring. but the bad is you might need to drop the pan to get the kick rod off the cable. its been so long i cant remember correctly. easy tho.
  3. nerraw117
    Jan 5, 2005
    788
    charlotte, NC
    the passenger side? does it have a rubber end?
  4. nerraw117
    Jan 5, 2005
    788
    charlotte, NC
  5. paulmoon
    paulmoon 1/2 ton status
    Feb 11, 2004
    211
    Reno, NV
    Changing the cable is easy. Did it last week. Once you remove the bolt, you can pull the cable out a little and the end of the cable is a little metal piece with a small hole in it. the part that comes out of the trans is just an "s" piece of wire that sticks out of the trans. It won't fall inside. Once you remove the bolt it's pretty clear how it works. It's just hard seeing up in there! No pics though. Sorry. Good luck. :D
