Tranny Leak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sickquad, Oct 26, 2003.
  1. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    My 700r4 is leaking after I put a torque converter in it. So I am assuming it is coming from me banging up the front seal of the tranny where the torque converter goes onto the tranny. I know it's not the tranny pan. Does anyone know what is involved with fixing this seal. Do I have to pull the tranny apart or can I just lower the tranny and put in a new seal? If I do have to pull the tranny apart to do it, how much of a process is it to do this?
    Chris
  2. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Front seal replacment is easy.pull the tranney,remove the converter and the seal is right there.
  3. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    take a few pics of the seal replacement and post how it went. i have some leakage as well and the wife is giving me a load of crap over the drip pan in the driveway...
  4. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Its real easy folks. No different than changing the tail shaft seal... pull the tranny down, remove the torque converter, remove the seal (best to use a seal removal tool, since its a tight fit. Reinstall the new seal, and reverse the process. Nothing to worry about... just have a buddy, a good trans jack OR BOTH available to help! /forums/images/graemlins/wink.gif
    -Dan
  5. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
    if that doesnt do it
    get a Haynes book
    it shows how to rebuild
    and replace everthing,
    i hope thats all it takes is a front seal
    from past practice with 700r4's
    it was the front pump seal
    that was leaking on mine,if thats the case
    also replace the bushing
    good luck and let us know how it goes
