tranny linkage
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ducati-cooter, Feb 24, 2002.
  1. ducati-cooter
    ducati-cooter Registered Member
    Jan 24, 2002
    78
    Madison WI
    wondering what would have got bent as far as tranny linkage when raising the body for the replacment of the body bushings. I am having some problems with getting into the correct gear and it won't lock into park properly since i did this
  2. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    FIRST I NEED TO ASK YOU A ? HOW MUCH LIFT AND DID YOU INSTALL AN EXT. ON THE SHIFTER ROD?
    IF YOU DID A MILD LIFT YOU CAN JUST ADJ. THE SHIFTER ROD ON THE SIDE OF THE TRANS. THEN AGAIN YOU MAY ONLY NEED TO ADJ. THE SHIFTER IND. STRING UNDER THE STEERING WHEEL
    I'AM NOT YELLING I JUST HATE THAT DAMM SHIFT BUTTON
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Check down by the trans where the rods connect there should be a bolt there that you can loosen and slide on the rod for adjustment. It might just need adjusted since the sag is gone from the worn mounts.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  4. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    Just look at where the tranny linkage rod attaches to the tranny. That is where the adjustment is. Loosen the bolt and then re-tighten after the rod slides up a little. If it was bent anywhere, it would have to be up at the top where it attaches at the column. Hope this makes sense. If not, let me know and I'll try to elaborate.
    <font color=red>"PROCRASTINATE NOW!!!"</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/BigTex-Mean-Machine>http://coloradok5.com/gallery/BigTex-Mean-Machine</a>
  5. ducati-cooter
    Jan 24, 2002
    78
    Madison WI
    I just put new body bushings in without a lift but I lifted the body off the frame a great deal
  6. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    If I understand you correctly, you forgot to unhook the linkage before you jacked up the body to change the bushings. I did the same thing and I still need to figure out what to do to fix it. I did the one inch body lift at the same time. For me park is reverse and I have to use the parking brake all the time. Maybe someone has fixed this problem and knows how to explain how to fix it to us. Detailed description of the parts in question would help.
    If you knew the truth, you too would be against marijuana prohibition!
    Blue '74Blazer Topless W/ 35 BFG Muds1" Body Lift W/ Energy Susp. Bushings
