Tranny maintenance Q
Discussion in 'The Garage' started by Mastiff, Mar 25, 2006.
How should I service my auto tranny?
  1. Pull the pan and replace the filter.
    9 vote(s)
    64.3%
  2. Take it someplace and have it flushed.
    1 vote(s)
    7.1%
  3. Replace the filter AND have it flushed.
    4 vote(s)
    28.6%
  4. Do nothing, it's too risky.
    0 vote(s)
    0.0%
  5. Something else.
    0 vote(s)
    0.0%
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I've got a 1986 CUCV with TH400. The odometer says 41k, but it might be wrong. The service history is unknown. The fluid on the dipstick looks decent to my eye (fairly red, no chunks). I've been reading some bad stuff about not changing the fluid and then changing it. I've also been reading some real bad stuff about tranny flushing. At the same time, you get less than half the fluid out if you don't flush...
  2. goldwing2000
    goldwing2000 Guest
    If the 41k is accurate, you could get away with a filter change.
    If it's actually 141k (or 241k :eek1: ), just let it be. Putting in new fluid will wash away all of the varnish that's holding everything together.
  3. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    I have a habit of changing all the fluids on every vehicle that I buy.. That way I know what, when and how much I'm working with :D I have not had any problems with doing this on any of them..
  4. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Unless a used ride comes with very neat and clear service records indicating otherwise (and that's not the case with almost all trucks of this sort), all lubricants get drained/flushed, all filters changed, absolutely right. Even the axles get drained, covers removed, and the innards inspected.
  5. ascuro
    ascuro Registered Member
    Sep 19, 2005
    62
    SoCal
    Yeah, I do the same - every time I get a new vehicle, all the fluids get drained. It's the best way to see what you're dealing with, and if you're lucky, catch the previous owner's screw-ups and shortcuts before something really goes wrong =)
  6. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    At the least I'm going to drop the pan and replace the filter. My big question was whether having it flushed is a good idea. I was about to do it, but after surfing on it I have my doubts. Sounds like it can cause problems sometimes.
  7. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Complete fluid change is always good ! If there is something wrong it was going to go wrong anyways - not because you changed the fluid. If flushed properly all will be well . How thorough of a flush job really depends on the person doing it and how good the equipment is .
    Tom
  8. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I probably would flush it. After that you don't need to, just change the filter and what oil you can. That is what I do annually.
  9. william m. olsson
    william m. olsson Newbie
    Feb 21, 2006
    conn.
    tranny question
    Hello,
    How are you? Well you have a couple of different options to consider. How many miles ie. More than 80k miles and if transmission was serviced prior to you owning it. You could get away with replacing the filter, but that only removes about 25% of the fluid. It also determines what kind of condition the fluid is in. How dark is it? Does it smelled burnt? If so, air on the side of caution, usually a flush with filter change should do it. You can take it to any major auto repair center ie firestone, midias, or monroe and should cost about 200 dollars, unless you know someone. I hope that answers your question. Please write back and let me know how you make out. Any questions don't hesitate to write back.
    Good Luck,
    Bill
  10. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Most of the military vehicles will have low miles, and I would consider the 41K to be accurate. Still, I would drop the pan, change the filter and the fluid that is lost. You should be good to go.
  11. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    By all means Change the fluid. You dont really need to flush it.
    This is what I would do. Get a drain plug kit ($5.00) at your local auto parts or an aftermarket pan with a drain plug if you want to spend the bucks.. Pull the pan, install the plug, and change the filter. Then its no big deal to drain and fill with new fluid. Thay way you can always keep your fluid fresh and clean.
    If your trans has problems it will be ovious when you pull the pan.
    I have a plug in my trans pan. I drain and refill at least once a year. Keeps my 700R4 strong and healthy.
