Tranny maintenance schedule
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, May 19, 2002.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I have a 700r4 that was rebuilt about 14K ago. I dropped the pan and changed 5 qts and the filter after 6K, and did it agian today after another 8K...also put on a drain plug...I realize the tranny hold lots of fluid, in the lines, cooler, and TC...i'm thinking I'm gonna drain the pan every 2 oil changes...about 6K, and then replace the filter after 3 changes, or about 18K...will this replace enough fluid to keep my tranny strong? I've heard you don't really need to pay $70 to get all the fluid replaced when you do it reguarly...is this often enough? Any tips or ideas? Thanks
  2. 4xmac
    4xmac Registered Member
    May 1, 2000
    82
    Calif. Oceanside
    Your doing it right.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Yup yur doing it right.
    I usually change the fluid in my 700 around every 8K miles. And the filter every other change.
    The drain plug is the only way to go.
    I still have the orginal tranny in my 89 and it works perfict.
