Tranny makin screeching noise and throwing sparks
Discussion in 'The Garage' started by NITRO, Dec 19, 2002.
  1. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    I put in the new tranny etc...but now it is makin a screeching noise and hittin on something. i tihnk it is the tc hittin somewhere on the tranny. it will throw sparks. but, it only does it when i get on it...n e ideas?? thanx
    NITRO
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Where exactly is it throwing sparks from? I'd say that you probably don't want to drive it if it's throwing sparks... </font color>
  3. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    when i get on the gas, i tihnk the torque converter moves in towards the tranny and contacts something on there. i have 4x4 shifter boot off, and i can see sparks flying when i floor it and i makes the noise. but, the wierd thing is that it doesnt always do it and not always at the same rpm. so i tihnk im gonna take the torque converter out and see where it is contacting at. n e other ideas??
    NITRO
  4. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    is your bellhousing cracked?
  5. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    no, but even if it was, i dont think that would let it do what it is doing... /forums/images/graemlins/crazy.gif
    NITRO
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I'm not sure what's going on, but I'd sure love to see some video of it! /forums/images/graemlins/wink.gif
  7. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    Always hunting for video eh...
    All the advice i can give ya is take it out and see where the rubbing is at, that will atleast give you a starting point.
  8. Geno
    Geno Registered Member
    Nov 18, 2002
    52
    Dorchester, Nebraska.
    Have a short story for you. I purchased a Suburban with a GM crate motor in it a while back. Was going to use the motor in my Jimmy, Pulled the motor, was going to put a new oil pump in it before install, pulled pan, you could see where crank had been rubbing the journals, moved back and forth 60\1000, thrust washer on crank had big groove in it, Knew this couldn't be right, talked to an engine builder, he said this can happen when the internals of the torque converter let go, letting the torque converter actually expand when you put your foot in it, He said sometimes it will push the crank forward or it will expand and hit the front pump bolts on the transmission. This is what happened to me, just wanted to let you know what it possibly could be. /forums/images/graemlins/smirk.gif BTW I had to build a new motor because of this /forums/images/graemlins/angryfire.gif
  9. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Yep, same thing can happen if someone rides the clutch all day long. Puts end force on the crank and wears the thrust bearing out.
  10. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    well, looks like ill replace the tc this weekend. its a reman and has a lifetime warranty. thanx so much guys.
    NITRO
  11. phillymudhog
    phillymudhog Newbie
    Sep 1, 2005
    philadelphia
    ***hijack****
    i have an 87 blazer make a screeching noise (thought it was a belt at first) at high rpms just before trans shifts,when i first get on the gas it sounds like wind howling . what do you think bearing or trans??
