tranny mount case holes broken Q
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Jun 21, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    so how do you go about bolting a tranny to the mount if one or both holes are busted ? th350*
    what have some of you guys done to correct this ?
    thanks for anything
  2. dyeager535
    26,982
    191
    As in stripped out or broken clean off?
    Bungee cord?
    /forums/images/graemlins/rotfl.gif
  3. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Not a bungee cord............JB weld
    I don't know if there is a fis besides a new case. If you have the piece that broke off it might be able to be welded
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    half the hole gone, piece of case broken off, this is nothing new, has happened before, im am not surprised, just mad, getting another case is NOT an option, i specifically bought this drivetrain to put in
    thanks
  5. dyeager535
    26,982
    191
    Call an aluminum head shop (or aluminum welding place in general) and see what they have to say.
    Wonder if you could hold a steel bolt in place, and weld around it?
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Someone on here (I can't think of the username right now!) /forums/images/graemlins/eek.gif used something called an Ultra Bell that worked out VERY nicely. You cut off the front of the tranny housing, then bolt this King-Kong strong bell housing to the tranny pump bolt holes. It looked like a serious solution to the problem. /forums/images/graemlins/thumb.gif
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    problem is that there are no aluminum places around here, hmm
    i dont even think cast aluminum can be touched with tig or anything cept maybe brazing ?
    thanks
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    not taalking about bellhousing, talking about the tranny mount threaded holes pair just before the extension housing
    thanks
  9. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    thanks
    It can be welded by someone who knows what their doing using Mig or Tig, with the right setup. You can even gas weld it if you have the right setup.
  10. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    thanks for anything
    There is no easy way to do this, either have it welded MIG OR TIG is the only good way to do it.
    The other option is to make an external clamo style steel collar that goes around the tranny and the adaptor.
    I am working on a design that does that not for broken case but for strengthening purposes.
  11. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah the only real way to fix this is to find someone that can tig or something on cast aluminum and the area that i live in doesnt have anything liek that that i know of, is a low populated area we dont even have a tranny shop or salvage yard so hmm.,.
    what do i look for what process would this be technically called ?
    thanks
  12. dyeager535
    26,982
    191
