tranny mount question. need help asap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by James, Aug 29, 2000.
  1. James
    James 1/2 ton status
    Jun 22, 2000
    179
    Castaic, Ca
    Hey guys,
    I have a th350 with an np203. My question is:
    after I took off the adapter from the crossmember support. I then took off the rubber mounts which consists of 2 pieces. the top and bottom. I should say 2 pieces per bolt(2 bolts). Anyways on one bolt after taking it out with both rubber mounts. There was a metal sleeve about 2inches long that goes in between the the rubber mounts and thru the crossmember frame. then the bolt goes thru the metal sleeve. Well the other side did not have this sleeve. My question is: Does this sleeve belong there or not. The haynes guide does not show this part when disassembling. Please help
    Peace
    James
  2. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    Yes it should be there it keeps the blot from being to tite. If you replace the mount the new should come with the missing part.
    I understand the jeep thing I drive a BLAZER!!
    Ken
  3. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    you need the sleeve. I just replaced my mounts and they both had sleeves. I reused the originals but you'll need to buy another one.
    Bryan
    [​IMG][​IMG]
    Durant, Ok
    '79 Blazer in progress
  4. James
    Jun 22, 2000
    179
    Castaic, Ca
    What a joke. The dealership was only place in town with the new rubber mounts(old ones weathered and cracked). New sleeves did not come with and dealership had none. I guess a can make one from pipe?
  5. laketex
    6,220
    North Texas
    I got my mounts at NAPA and the sleeves were optional. But yeah I don't think they'd be hard to make out of pipe or something. I think they need to fit the bolts pretty tight though. Good luck.
    B
    [​IMG][​IMG]
    Durant, Ok
