Tranny: New v. Rebuilt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by johnny reb, Jan 27, 2001.
  1. johnny reb
    johnny reb 1/2 ton status
    Mar 6, 2000
    326
    Pittsburgh, PA
    Now I don't want to start the debate over the 700r4 tranny again, but mine is shot. Blew out 2 weeks ago. Seems the consensus on this board is that a properly rebuilt 700r4 can last a long time. However, I've also heard that it's better to go with a brand new 700r4. Should I go brand new or rebuilt?
  2. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    my 700r4 blew out at 165000 miles on my 1987 k5. I had it rebuilt with all the goodies ( heavy duty torque converter and corvette servo, etc ) and it runs better than ever. the total for a rebuilt ( upgraded ) one ended up pretty damn expensive, but at least the shop that did the work will warranty all of it.
    baja surf nazi
  3. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I would talk to the Racer Guys in your town and find out who does their work....if you get a New one (from the dealer?), you get the same thing you started with....if you buy one outright from Jet Performance, you get a "New" tranny that is totally different from the dealer, and is dang near bullet proof...or...you can have your local (NOT amaco) tranny guru rebuild yours with parts that will suit your needs and wallet....big clutch paks, Vette parts, hardened Sprag, aren't all that expensive, and usually will fill the needs of a daily driver/weekend warrior.....whatever you do...get a BIG aftermarket cooler.....the newer 700's have a 9 vane pump, and have solved the oiling problems to the tail that plagued the early models (pre 86)...you'll get lots of advice on this...if ya got $1500, I'd jump all over the Jet 700R....I got a Jet kit in mine, and I love it...best money I have spent so far......good luck...JD
    I'm at 10th and Plum....10 miles from nowhere, and Plum out in the sticks....
  4. turbo
    turbo 1/2 ton status
    Feb 18, 2000
    109
    If 89 or newer rebuild if not I would again buy from bowtieoverdrives.com
    I considered a rebuild but the chevy parts recomended as needed with the B&M kit to bring up an 82 to 89 (all recomended by kit) cost an extra $1200 from GM so I sent the kit back to summit and went with bow tie overdrives.
    Have been very satisfied.
  5. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Give these guys a shot, at least take a look.<A target="_blank" HREF=http://www.700r4.com>http://www.700r4.com</A>
    <font color=blue>Professional <font color=red>JEEP EATER</font color=red>, it's a population control thing.</font color=blue>
  6. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    bowtieoverdrives.com and 700r4.com are the same site. I'd have it rebuilt. But after seeing Mr.reds sticker on the blazer he just bought, looks like a new 700r4 from 91 only cost $889, versis 1300 for the rebuild.
    However, If your going with the re-build, "I" wouldn't put the corvette servo in there. The extra bang with the bigger servo tends to be more harsh on other drive line parts. An RV shift improvment kit will do the trick to help get the tranny to shift quicker to cut down on heat. But if you go with the big cooler you shouldn't have any problems with heat. The heavy duty sprag is a must and get the thicker clutch paks and you should be good to go, with all new seals and o-rings too of coarse. And to the best of my knowledge the JET trannys are re-furbs that meet their standards. I dont think they are "NEW". Go to there site adn read. I think you'll find that they quoted that they are rebuilt to their specs.
    Will work for parts, beer and sex.
    90 Jimi,350/700R4/241/10bolts/3.73's/33's/4"
    <A target="_blank" HREF=http://mccordhouse.freeservers.com>http://mccordhouse.freeservers.com</A><P ID="edit"><FONT SIZE=-1>Edited by ftn96 on 01/28/01 08:06 AM (server time).</FONT></P>
