Tranny not shifting into 3rd. PLZ HELP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rebel222, Jun 22, 2002.
  1. rebel222
    rebel222 Registered Member
    Aug 21, 2000
    58
    Louisiana
    My th350 will not shift into third except for when it has been sitting overnight. It will shift probably twice if I go straight to the highway and then not againg for the whole day. PLEASE HELP.
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Try it at wide open throttle yet?
    General Motors service manual says...
    1. Control Valve Assembly
    1a 2-3 shift train stuck
    b Valve body gasket- leaking, damaged, incorrectly installed
    2. Direct Clutch
    2a Pump hub - direct clutch oil seal rings - broken, missing
    b Clutch piston seals - missing, improperly assembled, cut, pistonal ball check stuck or missing.
    My guess would be a stuck shift valve. Now would a good time for a shift kit while you have the valve body off cleaning and examaning. All the valve body is a maze of passage through which tranny fluid passes. The pressure on the fluid is controlled by the governor and modulator. When the pressure reaches a certain point, it pushes open one of those little valves and operates the desired shift. Or something like that. I may be wrong, but I think that's the way it works.
