Tranny or clutch problems in my 6.5L
Discussion in 'The Garage' started by ironnut, Sep 15, 2004.
  1. ironnut
    ironnut Registered Member
    Jul 14, 2004
    77
    Missoula, MT/Redmond, WA
    I have a 98' 6.5L 3/4ton w/ the manual NV4500 transmision. Im having problems all the sudden with getting it in gear. Sometimes ill pull up to a stoplight, put in in Neutral, then try to shift into gear and I have to pull really hard to get into a gear. And its all the gears that It wont let me get into. And going into reverse it always grinds, or its hard to get it into as well. But other times it shifts normally. Im thinking this might be a sign the clutch isn't completely disengaging or maybe something worse. Any help??
  2. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Clutch slave cylinder or master cylinder bad? Only thing I can think of that would cause clutch to not completely disengage.
  3. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    hows the pedal feel? Mine was good- Until I lost all my fluids- I'd check the master/slave/o-rings for leaks. Even replacing the master/slave/o rings shouldnt be more than 80 bucks if you do it yourself.
  4. ironnut
    Jul 14, 2004
    77
    The pedal feels good, i havnt noticed any leaks but ill have to check more closely. I noticed that if i cannot get it in a gear i'll let out the clutch then push it in hard and then i can get it in a gear. So It must have something to do with the clutch.
  5. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Had the same issue for a while- And then off a sudden, bam, the O ring blew out. not fun.
