tranny pan gasket...is it suppose to be juicy?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 77Jimmy, Jul 22, 2003.
  1. 77Jimmy
    77Jimmy 1/2 ton status
    Sep 3, 2002
    661
    Atlanta, GA
    Ok, I think I have tracked down my tranny leak and I'm hoping it is this simple. My tranny pan gasket sticks out a hair all the way around the pan. I can squeeze it and see the fluid come out. Is this normal?
    The other place where I think it is leaking is on the driver side of the tranny pan, where the shifter goes into the tranny (I *think* it's the shifter...help here, I'm an idiot). I can see the fluid and I think it runs down onto the gasket and then spreads around the pan. Is this possible?
    Thanks! /forums/images/graemlins/grin.gif
  2. 77Jimmy
    Sep 3, 2002
    661
    Atlanta, GA
    Anyone??? /forums/images/graemlins/confused.gif
  3. ji240
    ji240 Registered Member
    Jul 30, 2002
    16
    East Haddam CT
    The tranny pan and gasket should be perfectly dry. Drop the pan and replace the gasket ( Dont forget to do the filter while you are in there )When you buy a gasket make sure it is flat and not folded up in a box.
    Hope this helps
    John
  4. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    i like my steaks and women juicy, but usually not my tranny pan gasket /forums/images/graemlins/grin.gif
  5. 77Jimmy
    Sep 3, 2002
    661
    Atlanta, GA
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    Thanks, guys. I dont' know what kind of gasket the former owner used but it's nice and juicy.
    Suggestions on brand and where to get new gasket???
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    always use a felpro gasket never use a cork casket /forums/images/graemlins/thumb.gif oh and don't over tighten the bolts or you will pinch the gasket and it will leak /forums/images/graemlins/frown.gif
  7. fourwheelerjeff
    Nov 16, 2001
    3,419
    6
    better to spend a little money and get a higher quality tranny filter kit with a better gasket in it, try to snug all the bolts about the same but if you squeeze it so tight it is pushing the gasket out, then that is too much /forums/images/graemlins/eek.gif
  8. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,068
    479
    Grand Rapids area
    The shifter could be leaking. The seal can be replaced by dropping the pan, disconnecting the shift linkage and pulling the shaft out. The seal should be available from a tranny shop or a dealer.
    Try cleaning everything up and then checking it again in a day to track the leak down.
  9. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    but make sure you ask them if it has a cork gasket if they don't know open it up and find out there if it has cork don't get it /forums/images/graemlins/thumb.gif
  10. fourwheelerjeff
    Nov 16, 2001
    3,419
    6
    unless you like to keep the underside of your truck well lubed with atf, as well as your driveway and everywhere else you go /forums/images/graemlins/rotfl.gif
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    There is nothing wrong with cork gaskets. I've used them before with no problems. In fact, if your pan isn't perfectly straight, cork is the way to go.
    Then again, I once had that problem. I fixed it permenantly by swapping out my automatic. /forums/images/graemlins/smile.gif Then my 4 speed leaked so I sealed it up with 2 tubes of silicone. (I definitely don't recommend this be done on an automatic!!)
  12. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes cork can be used but felpro gaskets are way better so why not do it right the first time /forums/images/graemlins/thumb.gif
  13. 77Jimmy
    Sep 3, 2002
    661
    Atlanta, GA
    Can I get the felpro gaskets locally, at a Pepboys, Advance Auto Parts, NAPA??? I'm on their websites and I'm not seeing felpro.
    Oh, and thanks to all...exactly the info I was needing! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  14. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes you can get felpro gaskets at any parts store just ask for them /forums/images/graemlins/thumb.gif
  15. Grim-Reaper
    7,385
    Atlanta
    I agree.
    It's in the prep. It has to be absolutly oil free before you install the cork. I always wipe the surface the gasket seals to wil brake cleaner on a paper towel.
  16. rawhead
    rawhead Registered Member
    Dec 6, 2002
    52
    So. California
    77Jimmy, you might want to inspect the tranny fluid cooling lines that fit into the passenger side of the tranny. If there is a leak there it will drip down to the pan giving the illusion your pan gasket is leaking. and snug them pan bolts up!
  17. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i used a cork gasket in mine and its been fine so far! /forums/images/graemlins/thumb.gif
  18. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Mine seems to always be "juicy" and i've replaced it a few times and torqued the bolts to spec. Maybe it is a leak elsewhere, don't know.
    Anyone just use silicone and no gasket? This seems to work on other parts /forums/images/graemlins/1zhelp.gif
  19. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    i like using the neoprene gaskets from the dealer. i've never had a problem with one of them leaking. just my .02
