Tranny pan is killing me
Discussion in 'The Garage' started by sickquad, Oct 17, 2004.
  1. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    So I'm sick of everyone calling my K5 the Valdeze. The tranny pan leaks bad. It is a 700R4, pretty new cast aluminum pan with the big thick flange. I have been using cork gaskets with both sides siliconed. Any good tricks out there on making a tranny not leak for more than a week or am I just a complete donkey?
    Could I just use silicone? I think it might just get all pushed out though. What about torquing the bolts down without killing the gasket?
    Any advice would help, I know this is a stupid question don't remind me.
    -Chris
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I'd pull the cover and put it on a nice flat surface see if its really warped or something. Don't see why you can't use all Silicone. I do for most everything.
  3. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    those cork gaskets sucks with silicone. i found out its easier to use just silicone or go by those reusable gaskets. thats my .02
  4. ryoken
    Jun 13, 2003
    29,622
    1,376
    Jersey Shore
  5. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    try checking the bolts after a day or two of install, sometimes the bolts seem to loosen a bit and let the pan start to leak.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'd say it's the opposite, stop over tightening them.
    Oh yeah, and stop using silicone entirely on a trans pan.
  7. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    I agree, I would not want that crap inside something with as tight a tolerances as an auto trans. Dry gasket with nothing on it, maybe a little high tack to keep it in place.
  8. GMCLegacy
    Jan 24, 2002
    620
    Grand Haven, MI
    its a cast aluminum pan, if he is distorting it, he has other issues.
    and i said check the bolts, not tighten the hell out of them.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It's not distorting the pan, it's smashing the gasket that I'm worried about.
  10. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    torgue spec on the pan bolts are 12 ft lbs, not very tight at all. also no silicone.
  11. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Agreed. ATF will eat any of the sealer that squishes to the inside, then it will make its way into your filter and you will have issues. Dry gasket is the only way on a tranny pan.
  12. sickquad
    Jul 23, 2003
    785
    Ma
    So maybe I'm not that far off. I checked the pan on a surface plate at work, it's definitely flat.
    I was torquing the bolts to 15 ft-lbs.
    When you guys say you don't use cork gaskets, what kind do you use. The paper or fiber type. Neither Summit or Jegs have Fel-Pro tranny gaskets for the 700R4.
    Thanks for the help.
    -Chris
  13. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i use cork gaskets, just don't use silicone on the cork gaskets.
  14. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Stupid question time:
    Is the mating surface on the tranny clean of old gasket and old silicone?
  15. Storm Trooper
    Nov 24, 2000
    4,640
    I'll 2nd the Permatex High Tack spray.
    Use any gasket you like and don't over tighten the bolts. Do them all evenly and keep alternating like head bolts etc.
    If you see the gasket start to bulge slightly out of the side, stop! If you really want to be sure it doesn't leak, let it sit overnight before adding fluid and run a nice clean bead of high temp. silicone around the outside after it has setup.
    I never have any leaks with Permatex High Tack, ever.
  16. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    I've had good luck with the gaskets that come in the WIX tranny filter kits.I put them on dry--silicone is great for clogging the valve body and other delicate passageways in the tranny--I avoid using it on automatic trannys.If that doesnt cure it--I'd start looking real close for hairline cracks in the tranny case...
    On the subject of gasket sealers--High Tack is good stuff-if you have a rubber floor mat and never want to remove it again it works great to weld them to the steel floor,it works good on other gasket applications too.The most leak proof stuff I've ever used is Permatex"Indian Head"gasket shellac--it comes in a small brown bottle with a dauber brush on the cap like shoe polish--I used it on a radiator hose at the thermostat outlet that was badly pitted,wouldnt stop leaking no matter how tight the clamp was--a little "Indian Head" and it was dry as a bone--a year later I tried to remove the hose to put in a thermostat--had to use a hammer and chisel to get it off!.This stuff even works on carb fittings and other places soaked with gas or diesel fuel--but its a mean bitch to get off after it hardens,even a wire brush on a grinder has a hard time removing it--works good on pipe threads too--but consider anything you use it on to be permanent!. /forums/images/graemlins/crazy.gif
  17. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I'd just go get a new pan (nice alum one if you have the coin) and install one more time using the proper tq. spec.
    -Dan
  18. ryoken
    Jun 13, 2003
    29,622
    1,376
    Jersey Shore
    we use Wix stuff pretty exclusivly...
    if ya like the indianhead shellac, you should try this "gack" we use called PerfectSeal.. great stuff... kinda like the Permatex 300 series... we slather that stuff on all kinds of applications... /forums/images/graemlins/smirk.gif
  19. SUB-ZERO
    SUB-ZERO 1/2 ton status
    Oct 8, 2002
    219
    Virginia Beach,Va.
    Just changed my filter on my 700r 2 days ago with a rubber gasket no silicone(not good on a tranny!) and just snugged 'em up good(no torque wrench) and it isn't leakin'.Just rechecked the bolts and they are still tight also.
  20. jarheadk5
    Mar 6, 2000
    4,389
    PA
    I'll 4th or 5th the Permatex High-Tack - we use it at work for building up transmissions. Works great on cork or paper gaskets.
