tranny problem? i think
Discussion in 'The Garage' started by aealliarmy, Mar 29, 2005.
  1. aealliarmy
    aealliarmy Registered Member
    Mar 3, 2005
    75
    Newport News, Va
    today i got into my '88 stock K5 w/ auto tranny and put it into overdrive and when i pushed in the gas pedal it didnt move so i released the pedal and checked to make sure i had it in gear and it was so i pushed the pedal a little and it started to move extremely rough and jerky. i tried to get it to do it again but i cant reproduced the problem. and i have no idea. :(
  2. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Meybe this is an "oversimplification" but it sounds like it's slipping due to low fluid. Have you checked it? Often when the fluid is low it will slip like that until it warms up, then grab. Are you sure you don't have any leaks under there?
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,072
    483
    Grand Rapids area
    It could also be that your transfer case had slipped into neutral. This can happen when the shift forks get worn. Why not play with the shifter and see if you can get it to go into nuetral in some position other than N.
    It could also mean that a little junk just went through the pump or valve body. You might want to drop the pan and see if there is anything suspicious looking in there.
