tranny problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevycanada, Oct 10, 2001.
  1. chevycanada
    chevycanada Registered Member
    Aug 14, 2001
    33
    Comox BC
    when i first bought my 87 jimmy i check the tranny oil. it was clean and everythign seemed ok. about a month after i bought the truck it started having this clicking sound coming from it. i check the oil and it was dirty and stunk. i replaced the tranny oil and filter and a week later the oil is drity and stinky again. What could be the problem?
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  3. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Tranny could be toast. Remember too, when you pull the pan you only get 4-5 quarts of ATF drained. That is only a portion of what is in an auto tranny (valve body, converter, etc.). I usually let it drain, start her up, put in D then N then R then Park all with my foot on the brake (resting 3-4 seconds at each stop). Usually good for getting an extra quart out. I will run for another week and redrain, this time replacing the filter and pan gasket (the first time I just drain it which is easy with pan with a drain plug). You still don't get everything, but you get a lot more than just a single drain. By waiting to put the filter in until the second draining, you don't get as much crap caught in a new filter.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot>http://coloradok5.com/gallery/Leadfoot</a>
