tranny problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JerseyBlazer, May 27, 2002.
  1. JerseyBlazer
    JerseyBlazer Registered Member
    Mar 18, 2002
    28
    New Jersey
    took my k5 out today and found that it aint shifting properly. it shifts fine if i accellerate at over 1/4 throttle, but it gets stuck in gear at low throttle then shifts very hard, it does this in every gear, but it kicks down fine when i step on it. i checked the cable and the fluid and it all seems good. any ideas? its a 90 blazer with a 700r4.
  2. 88jimmyoungowner
    88jimmyoungowner 1/2 ton status
    Nov 20, 2001
    425
    georgia-rome
    i had the same problem. it was right after it was re-built. i took it back to the transmission shop and they fixed it. so maybe you could let a place look at it, and i think they said it was the cable of somesort. sorry about the lack of info, but hope it helps a little.
  3. tagurit
    tagurit Registered Member
    Mar 19, 2002
    25
    Nth E. Louisiana
    I've been told that on my th350, back rear right, there is a hose that can be pulled off a gold round thing (forgot name) and there is a screw in the hole of the gold round thing that adjusts the shifts. Too much and it won't shift at all so beware.
    after rebuild my tranny shifts rough if I get on it and that's what the guy said I could do.
    Take anything I say with a grain of salt.
