Tranny problems
Discussion in 'The Garage' started by ksblaze83, Aug 25, 2005.
  1. ksblaze83
    ksblaze83 1/2 ton status
    Sep 11, 2004
    329
    Topeka, KS
    I have a 99 silverado 4.8L w/the NV3500 (yeah i know). Anyways sometimes it is a BIYATCH to get into 1st or 2nd. I will keep it in neutral and let off the clutch and press it back in and keep trrying but it never friggen wants to go into gear, but after driving it for 5 minutes it will go away (sometimes). Sometimes it wont go away. Also i have had it kick out of gear a couple times on me (1st gear). And when i changed the fluid/oil in it, there was a tiny piece of metal, not a shaving but an actualy tiny piece of metal in it. Dont know if it's the clutch or if the synchro's or what?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    if you have little metal chunks in your oil i would think that your synchro's might be going bad. Are you getting any gear grinding when shifting?
  3. ksblaze83
    Sep 11, 2004
    329
    Topeka, KS
    sometimes it grinds, but sometimes not. It's kinda wierd, i make sure i'm pushing the clutch in ALL the way too. Seems like sometimes the clutch grabs at mid pedal and sometimes it's more towards the top??? Dont know if that's normal but the nissan, camaro, and mazda i had were al manuals and the clutch was pretty consistant when it would grab??? I just didn't know if it was worth throwing a clutch at it or if i should just start saving?
  4. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    i think you have a few problems...the clutch and the synchros. if you try to shift without the clutch will it sometimes work? if you try it just blip the throttle and see if it goes in...if it does then it will be the clutch and the synchros. same thing happened to my buddys tranny. both of the things were bad.
  5. ksblaze83
    Sep 11, 2004
    329
    Topeka, KS
    will try that one tomorrow...should probably just finish it off too. If i gotta spend the $$$ i myswell have some fun too!
