Tranny problems.......
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Trigger, Jul 11, 2003.
  1. Trigger
    Trigger Registered Member
    May 5, 2003
    48
    Independence, MO
    My tranny wont shift and has no parking gear. Does anyone have a clue to what the problem might be? I don't have the TBI that is suppose to be on there, do you think that could be the problem? I took it to the shop and they rewired a few things, replaced plug wires, and timed it. Before I took it there it would shift.
  2. 84K5cedric
    84K5cedric 1/2 ton status
    Aug 2, 2002
    279
    Austin, TX 78660
    did you replace the TBI with a carb? You better check your TV cable. If the carb came from an early model non-700r4 truck, then the arm won't swing right to give your TV the right pull. The shop may have made up for this by pre-setting the TV too high so only at high throttle will it shift right. Make sure it is at least hooked up!
  3. 84K5cedric
    Aug 2, 2002
    279
    Austin, TX 78660
    but i guess that doesn't explain the no parking thing.... hmmm would they have messed with your linkage?
  4. Trigger
    May 5, 2003
    48
    Independence, MO
    [/ QUOTE ][ QUOTE ]
    The no parking gear was a problem before I took it to the shop.
    What do you mean "TV cable"?
  5. Trigger
    May 5, 2003
    48
    Independence, MO
    I took it for a drive today and it does take a high rpm to get it to shift into other gears.
    Is there a vaccum line to the tranny that makes it shift?
  6. Trigger
    May 5, 2003
    48
    Independence, MO
  7. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    the TV cable is right below the throttle cable. it adjusts the fluid pressure in your tranny to control your shifts. if you stop by any tranny shop, they should be able to look at it and tell you where it's at, and if it's hooked up right.
