tranny probs
Discussion in 'The Garage' started by 88k5blaza, Apr 1, 2003.
  1. 88k5blaza
    88k5blaza Registered Member
    Oct 17, 2002
    70
    new hampshire
    i have an 88 k5 with a 700r4 that is about to die with an np208 transfer case i was wondering if i could use only a 700r or if this transfer case will bolt up to a th350 or 400? /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  2. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    doubt u could just bolt up a 208 off a 700r4 onto a th350... mainly because the output shaft on the 700r4 is several inches longer than the one on the th350.... the 208s adapter will be designed with that extra length in mind. Prolly need either a th350 with a 700-length output shaft or a different adapter for your tcase...
    j
  3. 88k5blaza
    Oct 17, 2002
    70
    new hampshire
    yea thats what i thought and another quick question i wasnt sure if you needed a 700 out of a 4 wheel drive or if you could just use one from like a caprice or something else that was 2 wheel?? wasnt sure about the tail shafts or output shafts if they were diff??
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Th400's also were attached to a 208. might be an option to overcome the 400's anemic 2.48 1st gear.
