Tranny Q's (non K-5 related)
Discussion in 'The Lounge' started by 1977k5, Jan 2, 2006.
  1. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    To sum up the story, we have a '92 Pontiac Bonneville that we purchased about 2 years ago. My uncle owned the car before us and maintained the car very well. At about 120K the tranny failed and was replaced at an AAMCO in Aurora for about $2500 (my uncle still owned the car at the time). The tranny had a 1yr 12K warranty on it. The car was sold to us a short time after for less than the cost of the tranny. About a month after we got it the tranny started whining and we took it back to AAMCO (still within the warranty period). The mechanic had to pull the tranny and replace what he said where the differential bearings. That fixed the whining noise just long enough for the transmission to get out of warranty. The car now has 155K on it, has a highway speed vibration and leaks from the driver side axle seal. Upon removing the CV to check the axle seal it was found that bearings are failing inside the tranny. Now, of course I realize the tranny is out of warranty. The thought I am having is that the tranny was faulty when it was originally installed and the problem was never fixed (I have no idea what the problem is, a warped case would be my best guess). Is there any leverage here or am I SOL?
  2. RustyParts
    RustyParts 1/2 ton status
    May 26, 2005
    235
    Wyman, Kentucky
    I would say you are SOL. Vibration in the CV joints is what destroyed the seals and tranny bearings in the first place.
  3. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    I'd say sol.:doah:
  4. 1977k5
    May 26, 2003
    9,996
    134
    CV's are fine, vibrations from differential bearings are what are causing the leak. I kinda figured there was no liability there.
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    WOW, the thread was labeled tranny Q's (not K-5 related) i thought there for a second i was going to have to bust out the "funny" pictures of the fruitloop across the street from me.:doah:
