tranny question
Discussion in 'The Garage' started by 409demon, Oct 11, 2004.
  1. 409demon
    409demon Registered Member
    Oct 9, 2004
    19
    Right now i have a lock up 350/208 in my blazer. I fried the tranny(the fluid looks like coffee) with my new engine and need to upgrade. i want to get rid of the slip yoke but try and keep my drive shafts. any ideas if a th400/205 or 350/205 are any wheres near the same length as a 350/208? Can you convert a 208 to a fixed yoke? /forums/images/graemlins/dunno.gif
  2. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I think the th400 and the th350 are the same lenght might be off a couple of inches. And there is an SYE kit for the np208 ORD has them. Some one will chime in with more info.
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    If you swap from a slip yoke to a fixed yoke rear output you will need to cut your rear shaft and weld a slip onto the tube. Your driveshafts won't "bolt right up"
  4. 409demon
    Oct 9, 2004
    19
    I cant find a SYE for a 208 on ORD. What about the half dodge/chevy combo how do you do that?
  5. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    there are no good SYEs for the 208 other than the swap with Dodge parts, which is no cake walk, or so I have heard...
