tranny question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Apr 8, 2001.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    sometimes at a stop light or just shifting into gear my tranny seems to take a second to engage. once engaged there are no problems. does anyone know why it would do this or how to fix it. thanks
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Check your fluid level. Probably your torque covertor. I cant really think of anything else because once you get rolling everything is ok, right?
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    what do you mean at a stop light? Just when you shift gears? If it is just when shifting gears it could be inside the trans, u-jt's, stripped out or not enough shaft on the Tcsae output shaft (if you have a lift), rear end, rear brakes not adjusted right so they don't hold the rear wheels enough...
    1987 Chevy K5 Blazer- 350 TBI
