tranny question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Redfrog, Jul 15, 2001.
  1. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    While sitting at stop signs the last two days my tranny
    has been slipping out of gear and going back in when
    I let off the break. It is a auto so what the heck is going on.
    It shifts fine. its is leaking a bit from the pan what is going on in there TIA
    HEY Fords!!! how many flushes does it
    take to get rid of you
  2. Storm Trooper
    Nov 24, 2000
    4,640
    Sounds like your loosing some clutches or a touque inverter. Drop the pan asap and check the filter. It might be plugging up and you will shell it if you let it go. A new filter and fluid doesn't cost much. If there is a lot of material in the pan and filter, get ready for a rebuild, it won't be long.
    [​IMG]<font color=red>[/b]"Rid'in HigH in my K5"[​IMG]
    ....[​IMG]<font color=blue>[/b]"6" Lift -<font color=purple>38.5's"[​IMG]....
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I have seen trannys do this when the pump can't build pressure to keep things applied. At lower rpm, the pressure drops. I would drop the pan and check that filter. If that looks good, prepare yourself. What tranny do you have?
    your right. I don't understand the jeep thing!
  4. Redfrog
    May 4, 2001
    753
    IL
    It has a 350th
