Tranny question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 65FL, May 30, 2000.
  1. 65FL
    65FL Registered Member
    Apr 11, 2000
    31
    Castle Rock, CO
    This is for a 84 K5 700R4. The tranny downshifts fine from 4th to 3rd, but it will not downshift
    from 3rd to 2nd no matter how hard I stomp on the gas. From my understanding downshifting
    from overdrive to 3rd is a mechanical linkage, 3rd to 2nd is vacum? Thus the problem might
    be a vacum leak. Any thing else to check for?
    TIA
    Roy
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    There is an actuator on the side of the tranny that handles this. The v-line may have been pulled off or the acctuator itself may be bad. I would check those first. i dont think the accuator is very expensive and I think there are some adjustable ones out there that will let you play with your shift point!!
    Mike
    82 GMC Jimmy "Emmett" "Built for function, not for beauty!"
    IN TOO DEEP Off-Road Club
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    It sounds like your detent or tv cable may not be adjusted correctly. I had a problem with my blazer not shifting well. I took it a tranny shop, the mechanic took it for a spin and adjusted the cable and drove it some more and sent me on my way. I bought him a six pack for his effort cos he wouldnt charge me for it. If your near Tucson I just happen to have a spare 700r4 if you need it!!!! good luck
    creepin and crawlin
    jim
