Tranny Question?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SWIVEL, Dec 6, 2001.
  1. SWIVEL
    SWIVEL Registered Member
    Jul 26, 2001
    18
    NEW JERSY(ARM-PIT OF THE WORLD)
    last week i did some hard wheelin and my tranny pan began to leak around the front. it took it off cleaned it up and replace the gasket. and now it still leaks. whats up with it?
    So I got that going for me.....which is nice!
  2. kilroy
    kilroy Registered Member
    Nov 25, 2001
    85
    Alaska, Anchorage area
    It’s an auto? Check around the dipstick, could be a simple O ring, if not Check around the modulator, or check cooling lines, if not these pull the inspection cover over the torque converter and check the front seal. If its not coming from ant of these you may have a small crack, pull the cover back off and give it a very close inspection.
  3. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    umm make sure the seal is real real real clean, use tiny bits of rtv and if that doesnt work
    J.B. WELD IT THEN WRAP IT IN DUCT TAPE
    Tork DSR
    "look ma, i can make the dog pee white...."
    aol screen name TorkDSR
    <a target="_blank" href=http://www.torkpig.homestead.com>http://www.torkpig.homestead.com</a>
