Tranny questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Trigger, Nov 1, 2003.
  1. Trigger
    Trigger Registered Member
    May 5, 2003
    48
    Independence, MO
    I have got to put a different tranny in 88 K5 Blazer. It's got a jacked up 700R4 and was wanting to put a 350 turbo in it. Was wanting to know if this will work and if so how? If there are any adapters or anything else that I might need to buy please put a direct link up so that I can find out what I need.
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    Re: Tranny questions *DELETED*
    Post deleted by R72K5
  3. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
    What tcase do you have now ?(prolly a 208)
    I did this like a year ago,
    you will need a 350 crossmemeber,
    drive shafts modified,
    the 208t case was a slip yoke
    where the 205 is a fixed yoke
    rear drive shaft made longer
    and front shorter
    if you have single exhaust that will have to be redone
    the adapter you need you can get from
    http://www.advanceadapters.com/
    you would be better off to get a 205 t case for the 350
    that way you dont need an adapter
    hope i was of some help
    other peeps will list anything i forgot
    or corret me if im wrong
  4. k5guyva
    k5guyva 1/2 ton status
    Oct 26, 2003
    165
    Southeast VA
    Just a point of reference regarding cost. My 700R4 recently died and sent it to local shop. I don't have the tools or the motivation to do it myself, you see. I asked about rebuilding the 700R4 vs a swap for a TH-350 or a TH-400. He told me the costs are about the same. The 700 would need to be rebuilt. The 350 and 400 would need some spacers and adapters as the splines don't match.
    So the answer to your question is that it depends on how much you are willing to do or pay to get it done. Yes, its possible.
    I have found that they now have a 350 (called a 350C) that has a lock-up torque converter. If you drive this on the freeway, I strongly suggest this upgrade.
    /forums/images/graemlins/k5.gif
    I ended up deciding to rebuild the 700R4 and add a few changes. I want a lock-up torque converter with a higher stall (about 1600-1800), new clutch packs from the 4L65E and kevlar bands.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    lockup feature doesnt save you as much RPM as you might think
  6. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    350 aint any stronger, its 1st isnt as low, and it has no OD... why do you want to go to it? 400 I can see the logic... but unless you have an extra th350 laying around right now I dont see the point...
    j
  7. k5guyva
    Oct 26, 2003
    165
    Southeast VA
    I like the 350 cause they are fairly cheap and plentiful. But I am rebuilding the 700 and adding some performance mods. It should have more torque off the line. /forums/images/graemlins/cool.gif
