Tranny Removal Problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by atodd, Sep 4, 2003.
  1. atodd
    atodd Registered Member
    Aug 14, 2003
    14
    Hey All...I was wondering if someone can suggest to me why I cant get my transmission off. I have a 1986 Blazer 4x4 with the 305. I need to take the tranny off because I have to replace my clutch.
    Ive taken all 6 bolts off and the thing wont move. I've taken the transfer case off as well thinking that it might lighten the load on the back side of the tranny, but it still wont budge.
    If anyone has any suggestions or tricks for me please let me know.
    Thanks,
    Aaron
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    The input shaft has to clear the pressure plate and clutch disc so the tranny has to move back about 4-5". Support the weight safely and pull it back...
    Make sure the linkage is disconnected, and it helps to remove the shifter from the topside. At the very least it'll be easier to muscle out from under the truck without a 12 foot long shifter sticking out of the top/forums/images/graemlins/grin.gif
    Rene
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Lol that damn thing is pretty long isn't it. I got in a truck with no body lift the other day and I was like damn the shifter is high what's up with that. /forums/images/graemlins/smile.gif I can't believe how tall they made those damn things...perfect for those of us with a 3" body on our trucks though.
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    It's probably a pretty short throw tranny...with a 10" shifter. The long shifter sure adds a lot of distance between gears though.
    rene
  5. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    On my K20, I was having a PITA time of getting the shift handle off. Couldn't seem to understand what Chilton's was trying to tell me. So I decided to heck with it. Problem was I couldn't move the tranny back far enough to disengage the clutch/pressure plate without the shift handle hitting the hump. After an hour of fighting it and trying to force everything, my girlfriend heard the three words out of my mouth that solved the problem...
    "Get the sawzall."
    By connecting teh cutout for the 465 with the cutout for the 208 shifter, it was amazing how much easier it was to get it to disengage!
    Oh yeah, as soon as I had it out from under the truck, I was able to remove the shift handle pretty easy. You know, one of those "Oh, that's what they meant" kind of moments!
  6. atodd
    Aug 14, 2003
    14
    I believe I have everything disconnected. I found 6 bolts connecting it to the engine and I took them all out. The shifter took us a while, but I called up a buddy of mine who works for Honda during the day, and comes home and works on his chevys at night...he came over and it took him about 2 minutes to get it out. I took the slave cylindar off too. Mainly because I was going to replace it anyway, but it got to be in the way so i took it off.
    I dont know what the deal is. I was wondering if I would have a problem if it was in gear or not. I dont know if it is, but I dont know if it matters also.
    If anyone else has any suggestions let me know.
    Thanks again,
    Aaron
  7. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    try this- disconnect the bellhousing from the transmission and try that- the person could have used a silicone sealer on the contact between engine and bellhousing.
  8. atodd
    Aug 14, 2003
    14
    That was it...I got the fiddleing with things and I disconnected the transmission from the bellhousing and it tranny slid right back.
    Now I just have the bellhousing to deal with. I already have all the bolts out of that. If it has that silicone sealer on it is there a special way to take seperate it, or do I just pry it off as hard as I can?
    Thanks,
    Aaron
  9. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    ok- on the drivers side, right below the slave cylinder, there will be a small indention about 3/4" long, that slants in toward the engine. get a chisel and light tap it in that spot to get under the seal then pry the rest off.
  10. atodd
    Aug 14, 2003
    14
    I didnt see any indentation on my transmission, but I did end up getting it off. I had to heat up the guide pins and beet it with a hammer till it was loose. Then I was able to just pull the rest off by hand.
    Thanks for all your help.
    Aaron Todd
