Tranny shifting problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by achuskies69, Mar 20, 2001.
  1. achuskies69
    achuskies69 1/2 ton status
    Jan 7, 2001
    229
    Raleigh, NC
    <font color=green> Ok, since i got my new motor, and my lift put on, i have started to notice lately that i am having trouble shifting from drive into reverse. I was in the parking lot this morning at school and i went to pull forward and put it in reverse to back in and it wouldnt go. I ended up doing a complete circle and pulling in my spot. It does this when the K5 is at a slight angle, the parking lot slops sideways. When i got pulled into my spot, i pulled it down in reverse to check it and it worked fine. This is the only place that i really have this problem
    any body have a clue how to help me????
    <font color=green> 82 K5 - 350, 4" lift, 33's 3.08's
    I love cowboy hats
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Try putting the parking brake on pretty hard. Do it before you put it in park, and it wont roll a little before it hits the park pin. I would think this should cure that problem.
    90K5
  3. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    do you have a body lift or suspensioneither way could cause it(if you dropped your trans xmember down for driveshaft angles)with a body lift did you lengthen the shift linkage/is it properly adjusted?can you hit park when it does this?OR is it goin through the gears and the trans itsef is not working(i cant really see this prob caused by a lift)my guess would be to check the linkage for correct travel,and check your body mounts to see if your truck is twisting xcessively.
    PURE INSANITY
    86 blazer silverado 400 horse 350 w/vortec heads 38 x15.5 swampers (40 hawgs next)10 bolts(blah)w/4:88s coming soon,14 bolt.
  4. achuskies69
    Jan 7, 2001
    229
    Raleigh, NC
    <font color=green> i didnt put a body lift on it, its all suspension, but i did drop the transfer case 1", so is this the cause of my problem? it happens when i am in the parking lot or at any slight angle, when i stop and try to go from drive into reverse or park, and if i pull forward usually it will allow me to shift into reverse or park..
    what the hell is the problem , damn this is wierd?!?!?!
    I love cowboy hats
  5. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Are we talkin about an overdrive tranny? Can you make it do it again or was that the only time it's done it?
    <A target="_blank" HREF=http://muddin4fun.coloradok5.com>http://muddin4fun.coloradok5.com</A>
  6. achuskies69
    Jan 7, 2001
    229
    Raleigh, NC
    <font color=green> yeah its the big 700 tranny, and it does it almost every day at school and in a few other places.
    I love cowboy hats
  7. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    Have you checked the fluid level?
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    your shift linkage is binding when you are at certain angles so you need to lengthen your linkage
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
  9. 88K5Rhododendron
    88K5Rhododendron Registered Member
    Sep 21, 2000
    25
    Outside of Rhododendron, OR
    My parents had a suburban that did that for a while, and then they lost forward motion, and had to have the tranny rebuilt. No one is will to blame my dad for this, but it is my guess that he forgot to check the fluid levels. Unwillingness to go into reverse in a o-drive tranny, such as yours is normally just because the fluid is low. And a little fluid is way cheaper than a 1200 dollar rebuild =) Good luck
    Matt
    gasoline4life! Or rocket fuel... I could see my blazer with some rockets on it... :)
  10. achuskies69
    Jan 7, 2001
    229
    Raleigh, NC
    <font color=green> i just had the fluid changed 1000 miles ago when i had the 350 dropped in, so it should be ok. How would i go about lengthening the linkage?
    I love cowboy hats
  11. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Might as well check it anyway...
    90K5
  12. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    I had a similar problem and my trans. mount was in two pieces. If I had any angle it would not shift once level no problems. New mount w/doubler kit no more problems.
