Tranny Slippage.....
Discussion in 'The Garage' started by RustBuket, May 27, 2005.
  1. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Well my tranny slips if I pin it while in 4-lo on a high traction surface.....Do you think this means my tranny is going to be dead soon or just take it easy when I'm in 4-lo? I'm going to change the fluid and filter to be safe and clean out the pan. Should I start lookin for a new tranny now? Its a TH350 btw. I also wouldn't mind switching to a SM465 but realize I'd probably have to swap d-shafts as well. What do u think?
  2. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    1. You probably checked already but how's the fluid level?
    2. Make sure the vacuum modulator hose didn't come loose.
    Your T-case is in 4low so what transmission gear are you in when the slipping occurs D, L2, L1? If your in L1 and it's slipping during the 1-2 shift then:
    Low fluid level
    low oil pressure
    faulty 1-2 accumulator
    faulty 2-3 accumulator
    front pump malfunction
    intermediate clutch malfunction
    as taken from HP books Turbo Hydramatic 350 Handbook.
  3. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    could be the torque converter. Im assuming you mean pin it in 1st gear, 4Lo.
    The band could be severely worn as well. maybe its just first gear, but it could be others as well...
  4. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    slips in 4 low??
    Strange--the tranny should be MORE likely to slip when the transfer case is in "high" range---putting it in "lo" REDUCES the amount of torque needed to spin the driveshafts by at least 50%...I'd think you would notice any "slippage" much more driving uphill on the street in "high" range if it were a tranny problem.. :confused: ....I've driven trucks with "blown" trannys home in "low" range that would hardly even move the truck in "high" range before..maybe the "slippage" is in the T-case??.. :crazy:
  5. RustBuket
    Feb 21, 2003
    1,618
    How could the t-case be slipping? I checked the level a week or two ago I guess I'll check again...if its just low fluid I'm going to be a little embarrassed.... :blush: Maybe its low fluid and when you gun it in first, all the fluid sloshes to the back away from the pickup or something? Just a guess.
  6. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    Put some of that lucas oil trans slip stuff and see what that does.
  7. RustBuket
    Feb 21, 2003
    1,618
    Where do you get that stuff?? Can u get it in Canada?
  8. jhellwig
    May 7, 2005
    420
    Bonaparte, Ia
    Most auto parts stores and some other places cary it in the states. Not sure about canada.
  9. RustBuket
    Feb 21, 2003
    1,618
    Well, I'll look around.
  10. trailblazer86
    trailblazer86 1/2 ton status
    May 16, 2004
    112
    North Shore of Lake Ontario
    You can get Lucas NAPA up here. I think Canadian Tire also sells it.
    I would check your symptoms again before adding anything to the fluid.
    As diesel4me said in his reply... You should notice the slip in high range more than in low range.
    As for the tranfercase slipping, I guess it is possible but not very likely.
    I have never tried any cranny additives, the rumors that I have heard is that they are big nail in the trany’s coffin. Supposedly they turn seals and friction material soft. The word used I believe is mush.
    Please don’t take this as gospel as I have never used any additives myself
  11. RustBuket
    Feb 21, 2003
    1,618
    Now that I think about it, NAPA does have it. They have that little thing you crank with the 3 gears to compare how much better the lucas oil coats the gears and carries up with them.
  12. jhellwig
    May 7, 2005
    420
    Bonaparte, Ia
    I have run the lucas oil trans slip stuff in a couple of tranies and have had no problems with it. All it is mostly is a higher viscosity tranny fluid. I put it in every time I change tranny fluid cause it makes ones that aren't slipping shift harder.
  13. RustBuket
    Feb 21, 2003
    1,618
    Is it an additive or do u use all of the Lucas product?
  14. jhellwig
    May 7, 2005
    420
    Bonaparte, Ia
    It is an addative.
