Tranny slipping - or not?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BPS, Jun 2, 2001.
  1. BPS
    BPS Registered Member
    Mar 24, 2001
    28
    Sooke, BC, Canada
    The tranny in my '91 Blazer is acting a bit strange.
    Lately the shifting between gears has become slower - no more nice crisp gear changes. It acts as though the tranny fluid level is low but it looks fine and smells normal. the problem is worse if the truck is under load or going up a steep hill. Then the shifting between gears really slows down!
    Is this a sign that my tranny is on the way out or could it be something else?
  2. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    may want to try doing a fluid and filter change. i enterec a mud bog in germany one time in my jimmy, and on the way home it would not shift into o/d and was acting all messed up. went and got a new filter and tranny fluid, fixed it right up.
    just mu .02, but clogged filters do cause problems like what you have.
    AIRBORNE!!
  3. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Yeah, try the fluid change first. If that doesn't work you can get you some Prolong Tranny treatment. That will buy you some time to save money for a rebuild.
    Steve Fox for President, 2004.
    Jimi Hendrix was re-incarnated in 1990 as my....JIMI
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Yeah, change the fluid. If that doesn't help, start saving.
    90K5
  5. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    You could also experience slipping if the Tranny has too much fluid. Just a thought. Have you checked your Transfer Case fluid? I guess the T-case might not have anything to do with shifting but anyways. Does the transmission feed the transfer case fluid on blazers? My '95 truck doesn't. That was almost an expensive mistake.
    Chad
