Tranny swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TheGeneral, Jul 10, 2001.
  1. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Have a TH 400/203 combo to put into K5 when I have cash for doubler (have a 205 that has to get converted to 32 spline female input). A question I just came up with when adjusting my TV cable after TBI spacer install, was when I swamp in the TH 400 that is off of 78 sub, where do I get the vacum for the mod. Just splice off of a vacum on TBI or what? New to the trans thing, but think I am going to try it as so far I am building my own. Thanks in advace for info.
    If you ain't hurt, you ain't playin' hard enough.
    The General
  2. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    All you should need is an intake manifold vacuum source. You should have a take-off from your throttle body. Just make sure it is not ported vacuum. Vacuum should be stronger at idle, weaker when you rev the engine.
    Robb
    '73 GMC Suburban - 502DFI
    <A target="_blank" HREF=http://community.webshots.com/user/robbrj>http://community.webshots.com/user/robbrj</A>
  3. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    If you can't find it let me know and I'll go out and take a pic of my setup to show you.
