Tranny/T-Case Combos
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by derek2002, Sep 16, 2000.
  1. derek2002
    derek2002 1/2 ton status
    Aug 1, 2000
    247
    Midland, Michigan USA
    Will a TH350 that is mated to a NP208 work with a NP205 t-case? What about a TH400 that was mated to a NP203... Will that bolt to a NP205 off a SM465 tranny? Hope you understand my questions. Thanks!
    Later,
    -Derek
    1977 3/4 Ton & Blazer Project (Body Needed)
    http://www.4chevy.com
  2. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    These will all work together, however, you will need the correct adapters and output shafts.
  3. slodawg
    slodawg 1/2 ton status
    Apr 30, 2000
    190
    Southern Arkansas
    go to http://www.advanceadapters.com they have a pretty cool page (not sure exactly where its at but its their) on what you need to crossreference for what your trying to do. Mainly its like jason73 said its all the adapter and output shafts.
    <font color=blue>SLODAWG</font color=blue>
    http://www.slodawg.coloradok5.com
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Advance Adapters has ecactly what you need and it will fit right, the first time. The adaptors are usually big money, though. Why not use factory adaptors? Wrecking yard, etc...
  5. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
  6. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    About 1/2 or 3/4 of Advance's stuff is just that OEM parts. As for it always fitting and being the best! I think not!! The last bellhouseing I got from them sucked! The bolt pockets for the bh to motor bolt were to small to fit a wrench in. The last adapter I got was clocked off by about 9 deg.
    I understand the jeep thing I drive a BLAZER!!
    Ken
