Tranny/t-case install
Discussion in 'The Garage' started by Muddytazz, Nov 3, 2004.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Last weekend I took the tranny and t-case out of my dads burb all as 1 lum unit(TH350/203). This weekend I get to put them back in. If I were to put the tranny and t-case back in separately, how hard is it to get to the upper bolts to be able to torque down? By looking at it sitting on the ground, looks like it would be a pita, but I could be wrong. What has everyone else done?
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    I used like 4-5 long extensions and a wobble to get them, was a pita but it worked well
  3. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    If you use the 4 or 5 extensions and a wobble put electrical tape around the wobble so it doesn't wobble so much.
    That's kind of a funny sentence.
    Or you could cut a hole in your floor.
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    good idea we used a spring on the outside of ours
  5. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    If you were able to take them out in 1 piece why dont you put it back in the same way? Was it just a PITA?
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Yes it was just a PITA. It's my dad's stock height burb with the exception of the 3" body lift(cause of a 2wd body on a 4wd chassis). Anyways, the burb is parked on 6" x 12" x 20' planks that are also 12" off the ground on blocks. He was trying to make it easier to get under there to work.....well that was nice, but all the damn jacks I own wouldn't go high enough so I ended up having to stack blocks on the ATV jack just to make it work /forums/images/graemlins/tongue.gif
  7. JDBlazer454
    JDBlazer454 1/2 ton status
    Feb 27, 2002
    951
    Vancouver, Wa
    What we always did was put an engine hoist through the door with a chain down through the shift hole and put them in together as one unit. Makes life a bit easier when your not fighting to work around a jack and it makes for lining it up with the engine easier.
  8. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    That would work just fine if I had a engine picker, but my engine puller consists of the rafter of a barn and a winch /forums/images/graemlins/doah.gif
  9. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    last time i did a th350/203 combo i put em in seperatly. i think i just got all the bolts started by hand, tighted up the bottom ones, then used a floor jack to lower the whole works down as much as i could (watch the distrib) to get to the top bolts. still a PITA. the 203 is such a heavy, wobbly POS to put back in.
  10. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Man do I ever know what that's like. /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
