Tranny/T-Case mounts?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazer79, Oct 4, 2001.
  1. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Hello guys. It's been a while. I need your help.
    My Blazer is not lifted, I replaced all 7 U-joints and sometimes I get this loud rattling usually when coasting. First I thought it was the passenger seat or the center console, but everything is tight. I also tightened the T-case crossmember. The noise comes somewhere near the tranny or transfercase.
    Should I replace the T-case mounts? Is there a transmission mount to be replaced? or is it only held between the motor and the transfer case? In otherwords, do 4wd Blazers have a tranny mount?
    It's a TH350 and a NP203, by the way.
    Thanks.
    <font color=purple>//////
    <a target="_blank" href=http://blazer79.freeyellow.com>blazer79.freeyellow.com</a></font color=purple><font color=black>
    Soon a 454 K5!!</font color=black>
  2. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    nope just on the t case
    Doug Krebs
  3. Blazer79
    1,816
    Thanks. That's what I thought.
    Is there a way of finding out if they are shot? Of course shaking the tranny/tcase combo would be impossible, unless I'm a wrestler, right?
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Have someone shift it from neutral to drive a few times for you while you watch it. If it's shot, I'm sure it'll be bouncing all over.
    Tim
  5. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Even if you don't see it bouncing, it can be screwed - if there's oil/ATF anywhere near the mounts, they're done for. Just replace them as a preventative maintenenace routine.
    Of the 5 toughest dogs in the neighborhood, my cat's ranked #3
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
