tranny/t-case question
Discussion in 'The Garage' started by bam bam k5, Jan 13, 2004.
  1. bam bam k5
    bam bam k5 1/2 ton status
    Sep 14, 2002
    107
    Newberry south carolina
    I want to put a sm465 in my /forums/images/graemlins/k5.gif. It currently has 700/241. The 465 has a 208 attached to it. Will the 241 interchange in place of the 208 behind the 465? /forums/images/graemlins/1zhelp.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you will have to change the input on the 241 to one that came from a 700r4. the 241 has a 27 spline input as the 208 has a 32 input spline
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    You will have to change the input on the 241 to one that came from a 465. The 700R4/241 has a 27 spline input as the 465/208 has a 32 input spline
    There I corrected it for you. /forums/images/graemlins/thumb.gif
  4. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    you'll have to get an adaptor also for the 465/241. if I was you I would just use the 208 if it is good. I beat the pi$$ outta mine and it kept truggin. justbe weary of the tranny/TC adaptor as i have broken 2 at the feet. just make sure you match your motor mounts (ie poly or rubber) w/ the tranny mounts.
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    He doesn't need an adapter, he already has a 465/208 combo which has the correct adapter since the 241 is a direct swap for a 208 assuming it has the correct input gear as I have stated.
  6. bam bam k5
    Sep 14, 2002
    107
    So I need to take the input from the 208 and put it in the 241. Then it should bolt up to the465, Right...
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I don't think the input shafts are interchangeable between the 208 and the 241.
  8. bam bam k5
    Sep 14, 2002
    107
    thanks for the info. guess I try and find a 241 input.
  9. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    find a SM465/NP241 combo froma 88-91 blazer. i have one, but my tailshaft is bent and i'm lookin for a NP205 and adapter.
  10. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    and in your sig. . .might i ask what "10bf" is?
    10 boyfriends? 10buttfaces (family site. . . think family site) /forums/images/graemlins/rotfl.gif
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I don't have any proof, but I think they probably are. The two cases share a lot of parts. Not sure if that's one of them or not.
  12. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    Did you ever think: "10 bolt front"? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  13. bam bam k5
    Sep 14, 2002
    107
    84_Chevy_K10, Is there anyway to find out without tearing down both t-cases.
