Tranny, T-case swap ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RacerHead, Jul 8, 2002.
  1. RacerHead
    RacerHead Registered Member
    Mar 30, 2002
    24
    Dallas, Tx
    I would like to put in a NV-4500 or a 700R4 in place of the Turbo-350, I don't know what T-case to run. I have a 203, I can get 205 or a 241 for $100 /forums/images/icons/laugh.gif . Does any one make a Doubler kit for a 203,241 ?
  2. Sinful_Nature
    Sinful_Nature Registered Member
    Jun 14, 2002
    90
    Raymond, NH
    If you already have the 203, why not set up 205/203 (Depending what you are building it for)? I'd say go with the 700R4 (above '88) for tranny. Make sure if you get the 205 it is the correct one. I made the mistake of picking up a 10-Spline 205 the first time around.
    ~ Russ
  3. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Even then the 10 spline 205 can be converted. Talk to Steve at ORD for the corect input and output shafts for your application...
    On the swap, I'd look for the NV4500, but count on spending some tall $$$! Slap a 205 behind it, and never look at the tranny again! Good luck, and keep us posted if you get the trans swapped.
    -Dan
