tranny/ tcase dilemma
Discussion in 'The Garage' started by chevyuser74, Nov 6, 2006.
  1. chevyuser74
    chevyuser74 1/2 ton status
    Jun 19, 2006
    1,473
    Mukwonago, Wi
    i currently am running a 350/203 setup and am looking at buying a 400/ 205 setup, but the more i look at posts at this sight the more i see people talking/ leaning towards a 700r4 for various reasons, although alot of ppl run the 400/205, i want to stick with auto so i dont need info on that, i can make the modifications to put any setup in, so what i need to know is what should i go with ...
    original setup and save my money 350/203
    buy a 400/205 combo
    or get a 700r4 in probably with a 208 then eventually swap in a 205 in time?
    also if u go with the 400/205 why, and if going to buy what to watch out for
  2. goldwing2000
    goldwing2000 Guest
    700R4 is WAY too fragile and difficult to set up for my taste. I'd go either 350/205 or 400/205. 400 is more bulletproof but 350 is almost as good.
  3. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    the 700R4 has the lowest first gear ratio of the three. 3.06:1 and has a 0.7:1 overdrive. the 700 isn't any weaker then the 350. A good rebuilt one will hold up. I run a 83 never rebuilt one. Maybe I'm lucky, mine is different from the newer ones. Found that out when I ordered my stall converter.
    I don't see what is so difficult to setup. The tv cable is super simple. you can get a 1 wire hookup for the lockup converter.
    now when it comes to the T-case. the NP205 is bulletproof. you can run one behind the 700R4, you will need a 350 to 205 adapter housing and a new tail shaft. advanced adapters has the shaft.
    My dream combo is a 700R4 into a klune-v into a 205. lighter then a 203/205 doubler, better gearing, and smaller. mostly because I already have the 700 and 205.
  4. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Bullet proof. The 400 is the strongest tranny out there and You can twin stick the gear driven 205.
  5. chevyuser74
    Jun 19, 2006
    1,473
    Mukwonago, Wi
    i got to say im leaning towards a decently built 700r4, im not doing any serious rock climbing or anything either this is just a mud, trail, truck plus i take long trips with it and overdrive would be nice
  6. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    get the 350/205 then you can use your original 203 and mate it back to the 350/203/205 doubler!
