tranny tcase swap
Discussion in 'The Garage' started by alf4444, Mar 1, 2006.
  1. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    Okay this may be a dumbe question but how the hell do I swap my tranny and tcase out without a vehicle lift. :confused:
    I'm running 6" and 35's and theres no way my jack will go hight enough and it's a big jack not one of those chease small ones,
    Any ideas?
  2. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    what kind of tranny and t-case? do you have a removable floor pan?
    if its an aluminum transfer case you can probably bench it out, if you have a removable floor pan use an engine hoist.
  3. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Also, it would be more work, but take off the tires, block the axles as low as possible...........
  4. AllamericanK5
    AllamericanK5 1/2 ton status
    Feb 2, 2005
    131
    Colorado
    Use an engine hoist. You will have to take carpet and a seat out for sure but then theres the hump that bolts in slide the engine hoist in and rap a chain around trani and tcase and lower her down i would do the pass side because theres not streering wheel or any thing to mess with good luck
  5. olskool
    olskool 1/2 ton status
    Oct 19, 2005
    138
    the frozen tundra
    When I put in my 465/205 I put the cherry picker through the passenger window, didn't even remove the seat and wrapped the chain around the front of the adapter and it balanced perfectly.
  6. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    or remove air from tires.
  7. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Remove air from tires or remove tires completely. Get a friend or two, buy em a beer and pull it out the way that grows hair on your chest.
  8. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
  9. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    Rent a trany jack? I have a 12''x12''x1.5' wood block that I notched to fit the flat of the adapter and the bottom of the trany. Redneck, I know but I have used it 6 times and it takes most of the work out of lifting the trany/t-case in. One guy on each side holding it steady and one guy running the jack, works slick.
  10. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    got pics?
  11. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    No pics, might snap one tonight. Real simple, v-notch 4'' deep on trany side, then flat on other side. the bottom of the trany rests in the V and the flat of the adapter where it bolts to the x-member sets on the flat. put it on top of your floor jack and you are set.
  12. Elevator Man
    Elevator Man 1/2 ton status
    Dec 23, 2005
    240
    Bigelow, Arkansas
    Just unbolt that bad boy and grab it like a man I pulled mine today by my self with no trouble!
