tranny temp gage install
Discussion in 'The Garage' started by MEPR, Feb 22, 2005.
  1. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    Alrighty whats the easiest way to hook one of these bad boys up? The directions say i have to drill a hole in the oil pan. Arent there some plugs i can take out and put the sender in?:confused:
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    The sender needs to be in the tranny pan reading the temp of the fluid that is about to go through the tranny, not fluid that is moving under pressure.
  3. flatline
    flatline 1/2 ton status
    Sep 9, 2004
    167
    Cincinnati, Ohio (area)
    Thanks I needed to know this also! Looks like I am tapping the pan too!
  4. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    alrighty thanks. Looks like my dad and i will be brazing that in when i get my 3/4tons.:cool1:
    sorry that was me (mepr) again, i should stop stealing pvfjrs computer huh...:blush:
  5. veris
    veris Registered Member
    Dec 16, 2002
    20
    Massachusetts
    Well if your not looking for the most "accurate" reading of the temp. Autometer makes manifolds that you can connect up to your oil sending line, to the radiator. I did this on one of my cars, and it seems to do a good job of telling me when things are getting hot, and it was an easy install.
  6. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    What type of tranny? In my 4l60e there was already a sensor boss that had a tapped plug in it. All that I had to do was take out the plug and screw in the sensor!
  7. short sub
    short sub Registered Member
    Jan 17, 2005
    98
    Sealy Texas
    i am running an autometer mechanical tranny temp gauge, it is exactly like a water temp. gauge except ,or course, that it is threaded in the tranny pan. from what weve noticed it is sometimes hard to get the electrical sender to ground in the pan and doesnt always work right. just a suggestion lata
  8. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Dude, make up your mind, is it mechanical or electrical? If there are no wires that attach to a separate sender then it is mechanical, if the sender is separate then it is electrical.
    Mechanical gauges use capillary tubes that are one piece with the gauge and the sensor portion of the assembly and does not require a ground to make them work unlike electrical gauges.
  9. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    Dude, I think his suggestion was to use a mechanical guage like he has because he has noticed electrical ones don't always ground well :dunno:
