tranny temp gauge on a th400?
Discussion in 'The Garage' started by jp0863, Oct 9, 2004.
  1. jp0863
    jp0863 1/2 ton status Premium Member
    Aug 15, 2004
    566
    clovis, ca
    is there a spot on the th400 that i can mount a tranny temp gauge? anyone done it? and got pics? thanks.
  2. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    I have plans to, but haven't done it yet. /forums/images/graemlins/dunno.gif
    So I'll give you a bump so I can get some info, too. /forums/images/graemlins/thumb.gif
  3. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    I did the B&M kit; the sender for it comes with a T-section and fittings, so you just cut out an inch or so of the tubing going to the cooler, then splice the sender in.
    Gauge proper went up under the dash, but I assume you're talking about the sender.
    The other option is to drill into the pan, which either means it's gotta stick straight down, or you gotta get one of those deeper-than-stock pans to drill into the side.
    -- A
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    On my 700r4 I put the sender (an electronic one) in the pump pressure test port.
    I bet the test port is somewhere near that on a th-400.
  5. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I went ahead and bought the remote transmission filter kit. It has the location for the temp sending unit built in and you get the temp of the fluid as it leaves the transmission on it's way to the cooler. /forums/images/graemlins/thumb.gif
  6. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    Yep, the th400 has the pressure port in the same location.
  7. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    I know you've already made your choice, but I need to put in my $0.02 since someone else hasn't chosen!!!
    The one thought is to monitor the temperature of the coolant output. With this, you know what THE maximum temperature of the transmission is, you know it can't be any worse than this.
    Put the sensor in the pan (my choice). This tells you the temperature of the oil the transmission is using, a better choice in my opinion.
    I have been able to mount a drain plug in a TH700R4 on the side of the transmission. NO clearance issues, it was pretty tight :-) I could snap a pick if you desperately need it /forums/images/graemlins/thumb.gif
  8. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Do you happen to know if that is the hottest fluid?
  9. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Putting it in the pump pressure test port will get the temp after the pump but before it goes to the cooler. This is most likely the highest temp in the trans. The hottest temp is what is going to do the damage (break down the fluid) so I would rather measure the hottest temp. There also isn't an easier place to put it /forums/images/graemlins/waytogo.gif The plug on a 700r4 is 1/8"NPT and so was the sender (electronic ...mechanical are bigger) so all I had to do was remove the plug and install the sender in its place.
    Don't use any teflon tape on the sender. It needs a good ground to get an accurate reading.
    We measure engine temp at the hottest place in the engine (in the head) so why not the trans /forums/images/graemlins/confused.gif Coolant is much cooler in the rad. or in the block.
  10. trukman1
    trukman1 1/2 ton status
    Mar 5, 2002
    129
    Ohio
    Any info on where to get an electrical unit as opposed to a mechanical unit? Thanks for the help!
  11. jp0863
    Aug 15, 2004
    566
    clovis, ca
    thats exactly what i was looking for, thanks ! i was thinking tere had to be a test port somewhere, but dont know much about the th400.
  12. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Mine is an AutoMeter from www.summitracing.com
    I'm not a big fan of mechanical gages because I don't like having to run that long tube that you can't disconnect from the back of the gage. Makes mounting it a pain. I have my gage in an A-pillar gage pod (in my s10). I don't think I could have run a mechanical gage if I wanted.
  13. trukman1
    Mar 5, 2002
    129
    Ohio
    Triaged, Thanks for the info. Now can anyone list the operating ranges that a TH400 ought to run at? Don't think I've seen that much info on this but I'd sure like to monitor the tranny as opposed to replaceing it! Thanks again! /forums/images/graemlins/truck.gif
  14. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    This is true for any auto.
